Ok So I still have a WOT issue....the car was running great no problems. It has a problem at WOT but only at 15psi or more, I have turned the boost down and no problems so it is not an rpm issue my guess is it is blowing out the spark under increased cylinder pressure.
Basically at WOT and only 15psi or more the car spits, bucks, and pops.....Zero knock.
I have confirmed my fuel is good both with pressure gauge and getting .770-.815 mv at WOT when going into condition.
This is what I have done please suggest any other places to look. Thanks!
At first the car would fall on it's face at WOT then I put on a spare coil pack and module (originally running a Type II) Now the car just spits bucks. Basically changed the symptom but still has a problem.
I tore into the wire harness and looked over every wire and ground, found my main ground wire to the battery burnt and corroded, replaced it....still did not fix issue. Found a broken ground on back of head, repaired still no dice. Ohmed out my spare coil pack-it's good....ohmed out my plug wires-good...replaced my plugs AC-r42ts.... My Cam sensor is good and tight and my crank sensor looks good also. I have triple checked all inter cooler hoses, no leaks, my maf readings on scan master look good.
I have looked every where I can think of that would cause this problem but have not found the solution. Is there anything you see that I may have missed?????
The only thing left to do that i can think of is buy a new ignition module since my spare has been sitting in my shed for a few years and I can not say for 100% that it is good, the last time I used it, it was fine but that was some time ago. Other than that I am stumped
ideas please!
ideas please!
