THM-200 vs THM-200C.. The difference?
Torx
What exactly is the difference between the 200 and 200C?
200C is just an overdrive model?
Any different internal parts revised in the C model?
Whats teh scoop?
200= nonlockup 3 speed
200c = lockup 3 speed
2004r=lockup overdrive(what is stock in a GN)
hope this helps
There may be some slight differences in the servo size depending on the application,but the servos are interchangable
The TH200 3-speed units will hold 8.5 to 9.5 quarts with a 12" converter. The 2004R holds 11 quarts with a 12" (298mm)converter.
