Thoughts? Scanner #'s INSIDE
notacarlo
eggs are liquid chicken
From SnapOn Scanner (old software)
AT IDLE
FP set at 45 psi as per Mr. Licht's instructions
Extender Extreme, Translator and 3.5" Maf. (set at 4% rich @ idle and 4% lean at WOT - all dips ON
Integratr: 147
BLM: 160
IAC: 48
Load/LV8: 22
Knock: yes
Knock Retard: 0
TPS: 0.42
No Codes Present
Idle: 800 RPM
02 mv: 191-746
I know this doesn't mean much at idle, but I gots to start somewhere. WOT numbers later tonight or tomorrow.
I used the Knock sensor test feature. 2000 rpm and tap near the KS. No knock. I'm beginning to think the sensor went bad....which is bad.
If anyone sees anything weird with these preliminary numbers, let me know.
Thank you,
Dan
Here's the WOT
Good, got it out on the highway....not what I expected.
RPM: 5000 - running out of room, looks like everyone is chasing me in reverse.
02: 766
Integratr: 128
Block Learn: 128
IAC: 101
Air Flow: 106 g/sec x 3 = 318...seems a little low
02 crosscounts: 0
Knock: yes
Knock Retard: 0
96 mph
21 psi
FP set at 45
Translator set: Base 0 = 3.5" maf
Translator set: WOT 2 = 4% rich
Looks like your lean at idle. You BLM's and integrator are pretty much maxed out. WOT doesn't look too bad. Obviously your chip locks the BLM's and Integrator at 128 at WOT. Hard to say, not familliar with the snap on software or how fast the updates are. To get a more accurate state of tune you need a program with a fast update rate like Direct Scan or Power Logger.
Yep.....I'm working on the directscan. Going to try and do a dual purchase with the MAFTPRO.
I have the new updated software too. I might do a run with those cards and see if anything changes.
No prob- just got mine, and, although I'm still in the learning stages, it's really cool! I went with the casper's quick-connect adapter- time will tell if it was the right choice....
