thrasher 100 octane chip for stock injectors
bose
I tried unsuccessfully to find out what kind of timing this chip has but here is my question.I always run Sunoco 94 and xylene for a 99.7 octane mix in the gas tank.I also have an SMC alcohol kit.With my Lubrant 94 octane street chip with 21 degrees of timing I can run 18 pounds of boost without the alchol with no knock.With the alcohol I usually run 21 pounds of boost with no knock.I made 1 pass at 23 pounds of boost with 0.5 degree of knock at the 1-2 shift and no knock after that but I did not go any faster.If anyone has a similar combination do you think realistically I can run 18-20 pounds of boost with this 100 octane chip?I have made it to low 12.4's with my other chip and that seems to be it.I am hoping I might go a little faster with this chip at 20 pounds if I can run with no knock.Bruce
No help but when i ran the thrasher 100 with xylene the chip did not seem to me to have alot of timing in it. No track times just seat of pants feel.
I plan to run this chip all time when I get my SMC. I hope I can push 21psi.
My car seems to like the trashers!
