I was thinking of doing that test. (High octane and leaving the solenoid hooked up.) It's going to have to wait until spring now.
The valve is just regulating the max boost right now. Scott said the chip boosts up to 19 psi, which is good, but too high for pump gas, so I have to turn it down anyway. At the track last week, I played with the valve and kept it just right. I was running 17 psi through first gear, and it pretty much stayed there the whole run. So even with the valve on the out port, if the solenoid lowers the boost, it could still drop below 17 psi, or whatever I have the valve set at. Unless the lowest the boost drops is 16 pounds or so, and I'm just not seeing it because thats all I'm running in the first place.
Here's an example of what I mean. These boost numbers are just numbers. Not using any actual stats. Say for example I open the valve and allow up to 18 psi, due to me letting the solenoid vent more pressure from getting to the actuator. I nail it, and it would boost up to 18 psi, and say its supposed to lower the boost in 2nd gear to about 16. So when the trans shifts into 2nd, the solenoid should still cut it down to 16. The valve has no effect, except on the max. It's just overboost protection. Takes the place of an adjustable wastegate for the time being.
Next track season, I'll hopefully have a few things fixed and upgraded, so I'll be taking it to the track and hooking up a scantool to see whats going on.
I'm sure its working right now. It probably lowers boost in 3rd a OD to around 16 or 17 psi, and thats all I'm running anyway in 1st and 2nd, so I dont see any reduction. Was just curious if it should drop in 2nd gear.
