Thread size at turbo oil return
Larry
What is the tread size at point where oil return from Turbo goes back into front of block? Thanks Larry
Larry, it is either a 1/2" NPT or 3/4" NPT. Can't remember which, darn mind.
The fitting is a 3/4" OD inverted tubing flare on the other end of the pipe thread.
paul
The opening in the block is a 1/2" npt thread-the tubing is alittle larger like 3/4".
