Thread Specs for Cooler Lines
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
What are thread specs for threaded holes in tranny for cooler lines? Wanting to run an external cooler and trying to determine the thread specs for inlet/outlet openings in the tranny case. Anyone? How large -AN fitting/hose should I run to get max flow/min pressure drop to cooler.
Conrad
i don't know what the actual threads are in the case- i don't think they are a regular NPT pipe thread- but the flared fittings that the hardlines go into are 5/16" flared tube fittings.
you can get bigger fittings for a 3/8" hardline from a 94-96 Caprice with the HD cooling (cop car, wagon, etc) and maybe pickups.
Case cooler threads are 1/4 in.-18 NPSM / NationalPipeStraightMale. Most use AN -6 size.
http://www.summitracing.com/parts/SUM-220027/?rtype=10
http://www.jegs.com/p/Russell/Russell-Transmission-Fittings/1398395/10002/-1
Jegs has some nice Hose & Fitting combo kits, may be cheaper than seperate prices. Just make sure they're long enough.
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&Ntk=all&Jnar=0&Ne=1+2+3+13+1147708&searchTerm=Transmission cooler line kits
