Throttle boddy for NOS
Roger
Got my JEGS catalog yesterday & see more ways to spend $$ on the TR.
JEGS lists an LT1 throttle body with nitros passages & nozzles. How would this piece work on a TR with alky? It's listed as 58mm.
Hi Roger,
The LT1 throttle body is an entirely different animal than a TR TB! They mean DUAL 58mm throats! Unless you have a total fabrication shop at hand, there is virtually no way to use it on a TR. Sorry!
How about a plate that goes between the TB and dog house that could be used for NOS or alcohol . Just need someone to start making thim .:).
That would require linkage mods. I'm sure it's doable, but the linkage would be an important obstacle to overcome as you could fry a tranny if you couldn't get the TV cable set correctly! Plus, it would throw off the up-pipe alignment at the IC outlet... just things to consider...
Yea, the linkage is why I never followed up on that plate. Dan has a plate that goes underneath the plenum that will inject whatever you want. People used them for alcohol and "other" things :)
I kind of looked into that plate, only problem was it would have to be a dry system and not a wet. He said that there only one entry on the plate not two. :(
Wet system would be a lot safer and easier to adjust.
Chuck
Uppipe or even the new under the injectors system is the easiest and best proven way to going.
Chuck
