TexasT
Texas, Where are you from
- Sep 10, 2002
So, I'm assembling the valve body and got to the tv valve. It has a small spring , a floating piece then a bigger spring, another piece that sticks out and the sleeve.
It seems like the small spring doesn't have much tension. That might be suppose to be like that. The floating piece doesn't really "snap" back with the spring pressure. I was thinking maybe a stiffer spring like out of a pen or something.
What does that bottom floating piece do?
I did put a firm spring from the 700 in the line bias, and the line bias spring in the accumulator.
Moving on to drilling some holes in the spacer plate.
Thanks for your input.
Rich
Rich
