87GN&98VET
- Jul 12, 2002
I'm working on integrating a contour to the rear thrust face of the 3.8L turbo Buick crankshaft thrust bearing to withstand additional loading due to ballooning of high stall torque converters. Can someone please confirm which side is the rear (that will react the thrust load from the converter) with respect to the locating tang - I believe it is the same side as the locating tang but need confirmation. These improved parts will be available in the near future. Part numbers are 107M (entire main set) and 7117CH (flange set only).
Sean Welch
Federal Mogul Bearing and Bushing Engineer
87 GN
98 Corvette
Sean Welch
87 GN
98 Corvette
