THS Rules- Redone See New Thread!
Status
Not open for further replies.
Slow91z
Turbobuick.com Helper
Staff member
2011 Turbo Hot Street Rules
General
1. THS will be run with a “heads-up” pro tree start and off of a pro ladder.
2. No peer technical inspections relating to safety equipment rules by class participants or peers. The track safety personnel will make all final rulings on safety related items.
3. Any vehicle is subject to being re-weighed and re-inspected (tech) immediately after the final round of eliminations or any other time deemed necessary by the Race Rules Administrator (RRA).
4. Any entrant caught deliberately breaking the rules or deliberately attempting to break the rules or breeches that violate the spirit of competition will be disqualified from THS.
5. All rules subject to revision at the end of the race season.
Chassis & Exterior
1. Lights, horn and windshield wipers must be operational.
2. Aftermarket fiberglass or carbon fiber bumpers and bumper filler panels are allowed.
3. MINIMUM vehicle weight including the driver MUST be at least 3500-pounds for a vehicle equipped with IRON heads and 3650-pounds for a vehicle equipped with ALUMINUM heads.
4. Complete stock and painted T-Type, Turbo Regal, Grand National or 1989 Pontiac Turbo Trans Am body required.
5. No fiberglass or carbon fiber body parts unless otherwise specified.
6. Stock wheelbase is required.
7. The engine and the firewall must be in the stock location.
8. Stock operable door glass windows, glass quarter windows (where applicable), glass front and rear windshields are required. No lexan.
9. Factory stock suspension locations required with any type stock location shock absorbers.
10. Stock front control arms required.
11. Any suspension stabilizer/ reinforcement bars or traction enhancing devices are allowed.
12. Sway bars may be removed.
13. No ladder bars or coil-over equipped rear suspensions.
14. Stock style coil springs required.
15. Outer frame rail notching is allowed. Inner frame rails must remain in the stock location.
16. Reinforcement at the inner rear frame rail is allowed.
17. No quarter panel modifications except rolled inner lips.
18. Minor modifications to the stock rear wheel wells allowed but no mini tubs.
19. Factory stock appearing front inner wheel wells required. Trimming for downpipe clearance is allowed.
20. No wheelie bars.
21. The brake system must be Power Master, Hydroboost, vacuum boosted, or manual brakes allowed.
22. A brake system line-lock is allowed.
23. The driver’s name on the side window is allowed. Sponsor or vendor decal(s) are acceptable on the rear window and rear quarter glass windows (where applicable).
24. A maximum of two (2) hood mounted gauges are allowed.
25. The Turbo Trans Am must use the factory production stock K-member.
Engine
1. Any production Buick V6 engine that was available from the factory in a passenger vehicle is allowed.
2. No Stage 1 or 2 iron or aluminum heads or engines are allowed.
3. Any type of valve covers and oil pan is allowed.
4. The factory stock intake manifold or cast intake manifold (i.e. Champion or BG Customs) are allowed. External welding, cold epoxy welding or puttying for performance enhancement is not allowed. An EGR block-off plate is allowed.
5. The factory coil pack bracket and right windshield wiper rod may be modified for clearance IF using an aftermarket cast intake manifold.
6. The factory stock plenum with a spacer or aftermarket cast aluminum intake plenum is allowed.
7. Any size single modified stock or aftermarket throttle body is allowed. Only a single throttle plate is allowed.
8. Any type stock location exhaust headers are allowed. EGT guage probe bungs that are welded into the headers are allowed.
9. Any single or dual exhaust system (3.5” diameter max for either) is allowed. Systems used must muffle and exit in the stock location(s). A closed (muffled) exhaust must be used during eliminations and qualifications.
10. Any diameter downpipe size (from the turbo) is allowed. The downpipe must be routed through the stock location. No flex pipe is allowed.
Turbo
1. All turbochargers, including billet wheel turbochargers, meeting the below listed specifications available prior to January 1st of 2010 are allowed.
2. One (1) 3-bolt turbo mounted and oriented in the factory stock position is allowed.
3. The largest turbo compressor available up to and including 67mm is allowed. The maximum opening size anywhere on the compressor housing inducer must be less than 68.5mm. One (1) single compressor opening only is allowed. No internal ported shrouds are allowed.
4. The compressor housing must have a three (3) inch INLET and a two (2) inch OUTLET (i.e. 3” x 2”).
5. The turbine housing must be a 3-bolt housing that was commercially available on or before January 1st of 2010. The factory stock appearing turbine exhaust to downpipe connection must be used.
6. Any wastegate configuration is acceptable, as long as it is routed back into the exhaust system prior to the mufflers.
Intercooler
1. Any stock location or front mounted air-to-air intercooler is allowed.
2. A front mounted intercooler may not extend below the bottom of the stock located radiator support. This does not apply to the front mounted intercooler piping.
3. No liquid intercoolers, intercooler external spray cooling or add-on cold boxes are allowed.
Engine Management & Fuel System
1. A stock or modified stock ECM or an aftermarket engine management system (i.e. FAST XFI, Accel DFI, MoTec, etcetera) is allowed.
2. A factory stock appearing (Type I or Type II) DIS cam position sensor is required.
3. No individual coil-per-sparkplug type ignitions are allowed.
4. No distributor ignitions are allowed.
5. Any air induction system is allowed but no hood scoops.
6. Any type of fuel pump(s), pump(s) configuration and location(s) are allowed.
7. Voltage increasing and fuel pump “hot wiring” devices are allowed.
8. Factory stock or aftermarket fuel rails are allowed. Modification to rails (either type) is allowed.
9. Any type of fuel pressure regulator is allowed. Any fuel injectors are allowed up to a maximum of seven (7) injectors. The seventh (7th) injector MUST get its fuel supply from the fuel rails.
10. Factory stock fuel tank with a sump addition is allowed.
11. Fuel Pump and Fuel Filters cannot be visible from the exterior of the vehicle.
12. Alcohol injection is allowed. It must enter the engine through the “up-pipe” of the air intake system.
13. Gasoline fuel only is allowed.
14. The use of nitrous oxide is NOT allowed.
Engine Compartment
1. The power steering must be operational, with the belt, in the stock location.
2. The stock alternator must be operational, with the belt, in the stock location.
3. Any engine compartment “dress-up” item is allowed.
4. The battery must be in the stock location.
5. Any stock or replacement radiator mounted in the stock location is allowed.
6. 1984-1985 Grand National/ T-Types, i.e. “Hot Air” cars, running in hot air configuration, may compete without factory installed air conditioning components. The factory heater box must remain intact.
7. Any car configured as a 1986-1987 Turbo T/ Grand National or 1989 Turbo Trans Am MUST have all factory installed air conditioning and heater components.
Transmission & Differential
1. Vehicle must use a 200-4R transmission to transmit power from the engine to the differential.
2. No other type of transmission is allowed.
3. Any torque converter is allowed.
4. Any transmission cooler and transmission pan is allowed.
5. A transmission brake is allowed.
6. Vehicle must have the factory 8.5” 10-bolt differential housing with a +/- allowance of one (1) inch. Turbo TransAms must use the factory production differential their vehicle was originally equipped with (with a +/- allowance of one (1) inch).
7. Use of a limited slip differential or a spool is allowed.
8. Any gear ratio with the factory stock or reinforced differential cover is allowed.
Tires & Wheels
1. Any matched set of four (4) chrome steel or aluminum wheels are allowed.
2. Rear drag slicks with a sidewall designation of up to and including 28”x10.5” are allowed. No “W” tires are allowed. Rear DOT street tires with a sidewall designation of up to and including 28”x12.5” are allowed. Rear DOT radial tires with a sidewall designation of up to and including 295-55 are allowed.
3. Rear tire footprint when installed on a rim and mounted on the vehicle cannot exceed a maximum width of 10.9” for DOT radial tires and 10.6” for drag slicks and rear DOT street tires, at 10 PSI checking pressure. Tires may not be shaved at the tread edge to meet the 10.9”/10.6” maximum tire width rule.
4. Front tire footprint must be at least 3.5” wide.
Interior
1. A full stock appearing interior is required.
2. Race seats are allowed only if the seats are attached to the rear crossbar of the roll bar (where applicable) AND the seats are painted and upholstered to match the factory interior.
3. Any transmission shifter is allowed.
4. Any type and number of additional gauges are allowed.
As stated before... I was targeted... and all of the ones who had a part in it will start denying it... right after this post...like it or not.. .this is BS... so let the playing dumb start where people start saying... i didnt know that would rule out your car... BS BS BS.... if you want to know how i really feel call me...I will be sure to tell any one.......
I was told my alot of people that this would happen if anyone outside of the click started posting faster times...... but they were completely correct.....
If I'm reading this right, this means most aftermarket downpipes that bolt right to the turbo aren't allowed? or are you just saying that the turbine 4 bolt exhaust flange must bolt up like a stocker would (IE not a weird one like the old 3-bolt 88)?
General
Chassis & Exterior
Engine
Turbo
Intercooler
6. Any type of fuel pump(s), pump(s) configuration are allowed.
Engine Compartment
Tires & Wheels
Interior
WOW!!!!!!!!!!!
1. Why would Collin be posting the rules???
Shouldn't the RAR be doing it??
2. Why are these rule's not VOTED on by the RACERS that race these races??
I thought we lived in the USA and this WAS a Democracy not a DICTATORSHIP!!!!
3. It is VERY ODD that the rules changes I SEE are directed at Sean and Myself????
NO FIBERGLASS HOODS AND NO AFTER MARKET CONTROL ARMS!!!
WHEN THE ONLY THING EITHER OF THESE ITEMS DO IS, SAVE A LITTLE WEIGHT !!!
OR LIKE SEAN SAID TARGET PEOPLE!!!!!!!!!!!!!!!!
WHAT ARE WE IN SECOND GRADE, IT'S MY BALL AND WE DON'T WANT THE SOUTHERNS TO PLAY!!!!
IF NOT, WHO EVER THOUGHT OF THESE CHANGES, PLEASE GIVE US ALL ANOTHER EXPLANATION!!!! PLEASE!!!!!
JD
This is where someone comes on and tries to twist words and change the point of the subject to lead people away from the original and core point of this. I have seen it done a several times by certain individuals.
The point is that these were very direct targeted additions to the rules to knock SPECIFIC individuals current car out of the class.
Of course it will be played off like "what?, really?, we didn't know that., your car wasn't targeted," blah blah blah..... hard to deny any of it when there is a huge a-- picture of breaking the class record showing everyone and it just so happens that is what was changed....BS...
Nothing personal, but I called BS months ago about people having inside information (look the thread up) and they all denied it and yet here are the rules posted by one of the very people that commented in that thread....:rolleyes:
I am sure they will not like me calling them down on this, but its the facts... read for yourselves.
It is what it is.... and it is a bunch of BS...
I had absolutely no inside info. These rules posted here tonight are the first time I've seen them. The fiberglass hood rule is a clarification of the last year's rules. That leaves the control arm one the only rule you two can be mad at then if I understand correctly unless you wanted them to repeal the fiber hood rule.
you didnt post the rules Kevin... so you can exclude yourself from the comment above.
As far as the rules......if they wanted my opinion in the making of the rules they would have asked me long before they came out... but it is hard to target a guys car and ask him his opinion.... it is so obvious that it is BS...
It isnt like they tried to "slow" the class down with the new rules....BUT certain car(s) were targeted to be now illegal which targets certain people....
Why can't the person(s) who DID make these changes SPEAK UP!!!!!
PLEASE!!!
1st off I posted the rules because I'm the one who since the beginning has done all the typing, posting, sending, ect. That's why I have been listed as the IT guy, it's my way of helping out, I had no prior knowledge of what changes were going to be made I found out approx. 24 hours before you guys so I could change them and post them.
As Kevin said the Fiberglass Hood rule was a clarification from last year, it was always illegal, but some disagreed with the way it was worded...Now it's spelled out clear.
Now I'm going to offer an opinion on the other rules, but that's all it is. When I was typing them up it was clear to me that the idea here was all about keeping this more of a street class, I mean I know you can drive around with a fuel pump hanging off your back bumper but even the people that don't know anything about cars will see it and say "Oooh look at the race car". **** my mom calls my car a race car.
General
6. If you live below the Mason Dixon Line you are not eligible to race.Chassis & Exterior
26. Any personalized tag with "WRAITH" written on it is not allowed.
Engine
Turbo
Intercooler
Engine Compartment
Tires & Wheels
Interior
5. All drivers with the first name of Sean and from the south are not allowed in our reindeer games.
I fixed it so it says the intention a little clearer.
Ok that's it, this is the rule thread, if you guys want to discuss start a new thread.
And yet again.... We are discussing the "RULES" but you dont like it so you want me not to post....Thanks for proving the last rule a little more clearer for the other readers.:biggrin:
BS! You are NOT discussing rules you are slinging mud, if want to start a fight do it in another thread this one is so people can read the rules and ask for clarifications if they don't understand what a rule says.
Aftermarket DP's that bolt to the turbo are fine as long as they use the 4 bolt configuration...In other words no V-bands and stuff like that.
Clarification: With exception of clarifying the hood (so you understand we are not dicussing the hood clarification in this particular sentence), why change the rules specifically to eliminate a specific car? (here comes the BS answer)
And so you know, there is no use saying that my car wasnt targeted because a couple of the other rule changes target only 1 (mine) or 2 other cars. Both more or less out of the same garage.
Cheers,
Sean
I have a old 67 turbo 3" in- 4" out with a PTE SL Intercooler so the turbo excludes my 4000lb LTD I guess??
Status
