tom robison
ALL UP IN THEM GUTZ
- Dec 11, 2004
I have decided to sell the drivetrain out of my ths project to help fund my stage 2 project.The motor and trans both were built by Lonnie at extreme automatics alittle over a year ago. I have only had the motor and trans running for alittle over a month and in that time have put 1690 miles and 9 11.20- 11.60 passes on it with a te-60 turbo w/ 20* timming, letting it shift on its own at 5200 rpm.This is a easy bottom 10/ high 9 second combo with the right turbo and tune.Motor and trans are still in the car and car be heard and driven. Here is what you get with this sale.
109 block w/ cat girdle
10/10 eagle crank
k1 rods
.020 probe forged pistons
218/224 comp hyd roller cam
ported iron heads with stock size valves(ferra I believe), and T&D rockers
ported intake w/ adjustable regulator, stock throttle body and doghouse
Trans is a stage 2 w/ billet drum and Art Carr non lockup converter 3300-3400 stall
With this sale you do not get any accesories or brackets, injectors, motor mounts, trans mount, exhaust manifolds, turbo, turbo drain or trans mount. Basiclly you get a long block with intake and the trans. I am asking $6800.00 for what is listed with out the wait of builders or machine shops. Thanks Tom Robison
10/10 eagle crank
k1 rods
