Okay, hope this link works:
http://members.verizon.net/carl.ijames/ChipFliprI/ChipFliprI.zip You should be able to right-click on it and save to a file. The next step up past 24 pins is 28 pins. I cheaped out and used a 2764-equivalent (or a 2764 itself if you want eprom) DS1225Y flash chip, tied the top three extra address lines high and put a switch to select the lowest address line past a 2732. That lets me select between two images and not have to mount a thumbwheel switch. In hindsight I should have used the tw and a 27256-equivalent flash because they are only a couple of $$ more than the ds1225 (about $22 each), which would give eight images. My board layout needs tweaking, too, to give a little more room around the sockets and I should put a ring terminal on the ground braid on the cable and put it on a stud, to really take the strain off the dip header connector. Anyway, it works which I thought was okay for a first prototype
. I put it in a little plastic box with rubber feet on the bottom, which sits on my transmission tunnel since I don't have a console. I'll repeat, the cable is the painful part if you do this. You might even want to consider replacing the socket in the ecm with something more convenient. Anyway, read the docs and post any questions. I had three boards made, built one for me, sold one, and have one left somewhere around here. I did the layout with pcbexpress so the three boards were between $60 and $80, I forget exactly.
Wow, tested the link and it actually worked
. Just click on it and you should get asked what to do with it; you don't need to right click after all (I'm such an intentional neophyte about html
