Time for a heated O2?
Roc87
11 Second V6
I've had a weird tuning issue with my GN ever since I've owned it. I've replaced the O2 sensor more times than I remember. It idles around 800 millivolts, about every 20 seconds the idle gets really rough and I noticed that the O2 drops to under 100 millivolts the whole time it's idling rough, after a few seconds (Sometimes) it smooths out and the O2 comes back up. I've checked all grounds, vacuums, etc....and everything seems fine, I have about 22 on the IAC at idle in drive, and 5 for the MAF. It is an AC Delco O2, and I think this weird problem is why I used to get a check engine light (Before I got DS). Ideas???
My O2s drop below 100 alot. Seems like everytime I let off the gas to slow down they drop to 000. They come back up after about 5 seconds or so, or if I give it some gas. It also drops to all 0s when I let off after flooring it. Maybe it is just the way they are? I know it's not my Scanmaster because I also have a a/f gauge that goes all black when the SM shows all 0s.
Yep, mine does that too, but this problem is just letting it idle. They do come back up right after I give it some throttle, but otherwise it stays under 100 for a while and the O2 cross counts stop....:confused:
