Turbo Indian
worlds quickest 6cyl bird
- Sep 25, 2003
it's been about 4 years since I have played in the mud. I started this project, & it's been sitting in a hole for so long the rear brakes are rusted up. but it's time to get it out & finish it. there is a warmed up 460 waiting to go into it along with a set of early 429 heads, a Jannis C6 tranny manual valve body with a reverse shift pattern, np205 transfer case, & if I can scrounge up the $$$ a blue bottle to go behind the seat.:wink: tires are 44" ground hawgs in the front & 44" boggers in the rear. about the only thing that needs done to finish it is plumb all the brake lines, set the drivetrain in, build a set of headers, & wire up the engine. about the only major parts left to buy is the GM style distributor, & the converter. hopefully I can get enough time this winter to finish it!
