I have seen over the years quite a few post mentioning that timing should be at ## number at the top of third gear or else? I believe I have even seen post mentioning timing adjustments at each shift point. The theory seemed to be if these adjustments weren't made knock would be induced.
Is there any particular reason this is the case?
I run the FAST XFI with MAP sensor and I am curious to know if this process is different with a MAP vs MAF system. Logic tells me it must be, if the advice mentioned above is only on a MAF system. I am thinking the engine doesn't necessarily care what gear the car is in or where in the RPM band it is. The MAP sensor tells the car ECM the load on the car and crank sensor computes RPM and based on such timing and fuel are dictated.
Am I in left field on this? As I evolve my understanding of tuning and get closer to my day on the engine dyno this will help me account for all possibilities.
