Timing chain cover
movinfast
I'm having problems getting my timing cover off any body here in Sacramento that's willin to help me or give sone advice on getting the cover off. all the bolts are out but it seems stuck around the top where the cam is.
Reply
Did you remove the bottom three pan bolts, There also is a hidden bolt in a recessed cavity directly behind the harmonic balancer generally buried in grease & hard to see & also the one most likely to be forgotten upon reassembly. The other issue is the cover fits tight over the two alignment pins that may have a rust build up making removal difficult.
