Just got done reading about 100 posts on rear main and timing chain replacement procedures and am about to dive in. I was thinking of replacing the water pump while there also. Cottons sells the delco replacement is this a good choice? Cooling system is up to par currently but you know while I have it apart. Some of the threads suggested checking out the front cover condition and doing a mod to improve oiling. The cover will not need to be completely disassembled to remove correct?? My car has 89,xxx miles and good oil PSI. 20-25psi hot 10-40 royal purple. Motor is stock never opened, this does not seem like a good idea to me what do you guys think? I have never messed with the front cover on one of these before and am a little intimidated by the whole thing. I have owned this car 15 years and would like to think I know a good bit about them but I also understand they are tricky to work on sometimes and when messing with the oil pump don't want to do something stupid.
TIA- Patrick
