I pulled my front cover to see that my tensioner had no rubber on it, now i was told that you can't put a tensioner on a Double Roller Chain. I didnt build this engine, but im taking parts off this 3.8(109) swapping them to a 4.1. So now here's the ??? This chain has a lot of play, and i can replace it with another double roller, but I want the tensioner. The engine im putting the cam in is a 4.1, and i notice it had a steel gear, so can i get a stock steel gear for a 4.1, and will it bolt to my roller cam with no problems?? Then i can run the tensioner, right?
