- May 25, 2001
A little while back I had a bad oil leak that I tracked down to the timing cover.
The little cap screw that has no reason to be there disappeared, most likely in to the engine. I pulled the timing cover just in case to see if I can find the piece. My hope is it made its way in to the oil pan. When I pulled the timing cover the cam button fell out, well part of it did. This is what I found.
There is also a nice gouge in the cover where the button rides.
Has anyone had the spring on the rollerized button break like this? Maybe the little cap screw hit it or bounced around a little in the cover and broke it? The timing gears and chain look good.
Should I pull the pan to find the piece or leave it be? (I don't really want to unless I really need to).
I had a small tick at idle I wonder if that was it?
There was no oil slinger, is it needed?
Also when turning the motor over by hand to line the dots back up (plugs are in) I thought noticed some air passing in to a coolant passage, I need to check further on that... leaking head gasket? I hope not, the car has studs in the heads so I will probably end up having to pull the motor.
How do I get the hoses off the PTE TurboSaver? They are rubber hoses, no clamps that I know of, is there a trick to it? I don't have the instructions.
Also, where can I find an oil priming tool for when I put this back together?
