I have a double roller timing chain installed and as i was test fitting the timing cover on i noticed a slight side to side wobble. after further inspection i realized that a small piece of aluminum attached to the cam sensor hole inside the cover was hitting the chain.
How important is this piece and is it ok to trim it down to clear the chain?
All measurements were in MM but you get the idea of the differences involved.
