timing cover
gsbuick65
wheres a good place to get a new timing cover? Napa has one for $100. it has the neoprene seal. are they any good?
i bought one from full throttle. have to have it machined thou it extends .053 past the oil pan rail.
Make sure you verify the oil passages don't have any flashing sealing them shut. james
got it today, well 1st had to take my old gear shaft and sorta bore the hole alittle, wouldn't slide right in. no flashing in any holes. if I lay a straight edge across gears Its has .004 clearance, is that good? other than that looks good--for something "made in china"
p.s. doesnt come with front seal
