timing help
84GNv6
is the timing ajustable? if so how? also is the tps adjustable...what voltage setting should it be set at?
The tps should be at .42 to .46 and you will need a chip that will let you control the timing like a Turbo Tweak chip. A scanmaster will be very helpful for all this and is a must for all TB's.
