joedontknow
- Jan 13, 2004
See if I'm right......
# 1 piston TDC
cam sprocket @ 6 O'clock
crank sprocket @ 12 O'clock
Is this the correct position for the timing (stock?)
Also, car is back-firing thru the exhaust.....
(this is a friends car so I haven't seen it yet and 'am not 100% what all he has done to it) which to me would indicate timing out of whack.
Also what about setting the cam sensor..I know you can buy a device that lets you know when it is set properly..but isn't there an easier way to do this?
ANY HELP would be GREATLY appreciated!!
Thanks,
JOE
# 1 piston TDC
Thanks,
JOE
