Powertechn2
- Feb 3, 2014
This may be a stupid question, it likely is answered here somewhere too, I did try to search and kept coming up with old dead unrelated posts, some dating back to 2003...
So, here goes.
How much timing retard is acceptable, and what factors change the varying amount of acceptable retard?
So, I did a bunch of work to the car last weekend, finally took it to work after a buddy was giving me a hard time. Got the air bag hoses fixed, a ton of vac lines replaced, installed the dump block off, and a shitton of miscellaneous stuff that was necessary.
Long story short if you don't care to read, I don't want any TLDR responses, so. reading 890 for mv I guess of the 02, which I know should be like mid 700's, and 1.2 timing retard, this went up as the car got hot, highest was 1.7... Car currently for some reason has a 195 tstat in it.
What is acceptable and what is danger zone when it comes to timing retard?
**Now for those who care to read on...
Found the nut on the boost control rod was loose, figured this might be why boost was fluctuating lower the more I drove the car. Also knew the builder 10 years plus ago would run 16psi on 93 octane (pre-10% ethanol) and 55psi static fuel pressure....
So, tightened the nut, gave a turn or so to the rod as I knew it was down on boost and the last guy was messing with all sortsa things and he was an idiot.
Also found the jam nut on the fuel pressure regulator was loose, was only at 37 psi.
Thought the car was about to run out of fuel on the way to work, had hoped it was low even tho the gauge read 1/2ish tank, it would fluctuate around a lot and tapping on the tank sounded really low. Added 6 gals of 93 and the damned thing is now at near full. Damn. Last guy said he had put a mix to be about 98 octane, but not really sure about this, it was in fall, said he added stabil, also unsure. Going to drain tank and run in the tractor before I swap injectors and chip to newer chip.
Found out car has a precision ta60 turbo, front mount that I think says precision on the side, was hard to read due to 10 years of dust and dirt, comp 212/212 cam, th down pipe, lt maf with translator. Trans was built by a guy in or near Roseville Mi, was supposed to be a great 2004r trans builder back then) has trans brake as 1st gear, 3000rpm 9 inch stall (had message stored in phone, kinda ran it over with my truck so going off memory), has 280 or 300lph fuel pump, heads are p&p cast, roller chain, upgraded valve springs... I fixed the hot wire also... Also has some unknown headers.
Car idled horribly and would stall, sometimes backfire soooo loud that on the way to work it did the backfire stall deal and as everyone turned their heads at me I just turned around and looked around like wtf was that as the car coasted in neutral to the light...
Fixed all the vac lines and a buncha stuff, found vac lines the middle previous guy tried to fix that seemed to just go nowhere other than to another melted vac line hanging down
Now the car idles, doesn't stall (hasn't yet anyways)...
So, work in progress.
So, here goes.
