Boostrules
- Mar 16, 2013
Winter project doing the timing set with original GM style complete set including nylon coated cam gear, timing chain, water pump (from Kirbans), cam button & spring tensioner. While I'm at it will replace the valve springs with comp cams 980-12 & felpro intake manifold gaskets. Do I need to do anything else while in there? I've read that the rocker retainer buttons should/could be replaced but have not found a source to buy them from. Because of this site, it's given me the balls to undertake this adventure with the great information provided. Any opinions and advice from the pros is welcome. Thanks in advance to all.
