I am making decent power in the rpm range I will use at the track with an a/f ratio of about 11.2. The timing is only 18 degrees in this range. If I want to add timing with the c16 will I need to revamp the a/f also. Should I only do it at the track a degree at a time and then make a pass or can I add 4 or 5 degrees and then make a pass using the same lbs of boost I used at 18 degrees and 11.2 a/f? I have a fast and no egt Thanks
