craig or someone have the fast wide band on a521 ford msd dist. set crank ref at 50 btdc and dropeed the dist in did this many times just line up #1 with the rotor and it is close maybe 4-5 degrees off now do i need to trick the sytem on base timing set if comp show 38 it is 34 on the light etc or cant seem to pin it down with cahnging the crank ref angle one way or another what am i doing wrong?
