SignUp Now!Wow, Im embarrassed that I did not pull the balancer previously. Once I replaced the key stock and reused the balancer and this took care of the timing issue. I tested it at 10 deg through fast and it was right on. So I reset the reference number at 10 and the timing reacts as it should but I have to recheck other settings in the fast program. Thanks again for the motivating advice Jerryl..I would start with replacing the balancer and key, and verify the crank isn't damaged.
Hard to accurately measure 1 or 2 degrees crank rotation close to TDC, and the same 2 degrees on the wrong side can blow stuff up.
Great news. Glad to hear it's resolved.Wow, Im embarrassed that I did not pull the balancer previously. Once I replaced the key stock and reused the balancer and this took care of the timing issue. I tested it at 10 deg through fast and it was right on. So I reset the reference number at 10 and the timing reacts as it should but I have to recheck other settings in the fast program. Thanks again for the motivating advice Jerryl..
Just remember that if the key slot in the balancer is damaged (which it appears to be) the issue may return.
I have another issue with this vehicle that is driving me bonkers! In the fast program, I am trying to set the ATS and CTS correctly. I have loaded the GM table and have set the bias to 2.2. The temp of the motor is 80 Deg, but it is registering maximum which turns the fan on. I can reverse the graph and the fan goes off. I have taken a voltage on c23 of the fast box and it read 3. something volts and mostly the same for the ATS. I have tried raising and lowering the bias with no luck. This all is with the key on but engine not started. I have also searched for information on the issue on the internet and nothing.
How would I do that?Post the tune file...……...
