timing
If depends ....... it is set in the chip.
If my memory serves me correctly, timing is set by LV parameter and that in turn is a fucntion of vehicle speed, rpm and TPS (I think).
Typically though, you "should" see timing around 35-40, idle, park.
Hope this helps.
ok i thought i had a problem. I'm used to the 11 degrees chevy is set at.
