Finally got the car running after replacing timing chain and installing the turbo setup, using a non modified edelbrock carb. Also still using the stock hei dizzy ( converted to 4pin) car idles high around 1200 rpm. Put it in drive and it dies. wants to over heat but the fan kicks in to control that. Headers get red hot and cannot get the idle down. Car spits when you Rev it. thinking it may be the distributor....so
I replaced the dizzy with a 79 vacuum advance type but cannot set the timing correct to get it to run again. I did pull the plugs and wires to start fresh with the new distributor and believe I may have that wrong. Ive done it a dozen times before and always got it right, someone bring me back up to speed with setting timing from the install of this new distributor. What am i missing. All help is appreciated, tired of banging my head against the wall.
http://www.youtube.com/attribution_link?a=gVucGpp-mko&u=/watch?v=usvuYlj0Y2Q&feature=em-upload_owner
