Tire hitting outer fender
Lynn D. Brown
I switched to the taller "B" spindles a long time ago and I also put in taller lower BJ's. Now my Pass tire hits the outer fender when the car bounces.
I understand that U can get a compression type tool that will let U push on the lip of the fender to push it out. Anybody ever heard of that ? Know where I can buy/rent one of those ? TIA for any help.
I remember reading some posts here on TurboBuick a while ago about a "fender roller" or "rolling" tool (not sure)...If you do a search and enter the words "fender rolling tool", maybe you'd get some answers to what you need...If I recall correctly, guys were using this tool to roll the REAR fender lips...but I dunno if it was made to work in the front though...
Well, that's it...Hope this helps...
Claude :)
Tire size may be too big, alignment may be off, bushings in the control arms on the pass side may be bad from the down pipe.
