I usually do around 20 psi. If it cant hook drop it to 17 but thats about as low as I would go. I just do a burnout until I see some smoke in the mirror and then stay in it for a couple more seconds to heat them up
17 will work....just a tiny hint....face your outside mirror so you can see your wheel well and you'll see smoke before you would in the rear view mirror to better judge how much
you want to smoke the tires. Also, on the first run, burn em good, then just a mild burn out after that...they'll be sticky the rest of the runs.
