Tl Boost Sensing Feature
PaulRV6
I would like to get your opinion on this feature, how it works and if it is a necessary option to have?
Is it accurate and make tuning any easier? It would be for the new version by the way. Thanks
paul
Boost sensing??
Paul, I have used it on more than 1 install and find it to be a valuable addition to the data.
Using it removes the need to remember what the boost ga. said about the time you were trying to look at oil psi, knok ga, H2O temp, and see how far you are ahead of the "Moostwang" in the other lane:D :D [That USUALLY requires a look in the rear view!!]
It also affords a long term look to see if you have boost control problems.
I'd buy it!!!I have the beta version of T-link 3.0.. IT'S NEAT!!;) ;)
Ditto what Chuck said.
I typically will fine tune test with DirectScan and then take some T-Link files with the boost sensing to confirm as much data as possible.
