What is this scanmaster patch I keep reading about?
I have been looking through quite a few threads trying to figure out why I get garbage data with my TLink. The data looks good most of the time but, when I go wide open throttle I seems to be missing data or it does not make sense. If I am just cruizing the data seem ok for the most part with a bad frame occassionally. I am also using a scanmaster and the data it returns always seems correct. I doubt there is a ground problem since the scanmaster always seems to give correct data.
The only chip I have for the car is a JL that was made around June.
The Laptop is a Toshiba Tecra 730XCDT
Parallel port set to normal, EPP
Allen
Allen
