There is a lot of dated info regarding the TRWs in various responses in this thread. The TRWs are not a heavy piston, and they no longer come with the heavy pin. The pin oiling design has been revised with oiling grooves along the pin boss since the early pin problem days. Especially if the pin fit is checked (which you should do on any piston), in my experience they won't have problems.
Nobody's disputing the advantages of the JEs lighter weight, floating pin, tougher alloy, yada yada. I just hate to see misinformation spread.
Cal, I hear you on the .030" overbore...if you can hone the block and run .005" pistons, that's a nice bonus. Has the machine shop had good luck getting a straight bore on these with just a hone? Several blocks that I've checked had .003-.005 taper from the top to the bottom; they would otherwise be good candidates for this but it's hard to hone several thousandths of taper out without getting the big part bigger.
