toggling the lock up t/c on my 84?
turbogimp
what is the best way to toggle the lock up converter on my 84? what wires do i splice into? what colors and locations? do i need a relay or will just a normal toggle switch work? thanks in advance.
On the ALDL connector, the ones you want are the far right and far left pins I think (it's been a while). You can insert something into the sockets to make a connection or splice into the wires behind the connector. I have mine triggered by a switch in the ashtray that grounds the far left terminal if I remember right. No relay needed, you're just grounding the circuit.
