procharched464
- Jul 28, 2016
This is my first post so please forgive me for it being a for sale post, but I'm done with the Buick V6 stuff and just Downsizing so I can better concentrate on my GS projects. All prices are plus ship from 29376, for additional pics email me at Trishieldterra2@gmail.com
TE45 fresh rebuild from Bison $450 sale pending
Would prefer to sell intake as a complete unit throttle body down if possible, fuel rail with AN -8 fittings, custom vac line setup,60lb Motron injectors,Champion 1in spacer, Ported Blasted Painted egr delete intake,Precision Plenum,new harness,coil,module, egr plate,billet water neck,sensors etc detailed with stainless bullet nuts and hardware slick looking setup $700 Sale pending
Custom Serp setup very tight and clean will include both water and crank pulleys with the required spacers ,PS pump, 120amp alt ,this is an UNTESTED setup but there is no reason why it will not perform as intended. $300
GN1 headers with Vbands $450 New
40mm Turbosmart gate $250 New
Ecu stock $75
Scan master $75 Sold
New HR engine mounts $200 Sold
TA valve covers $100
New Valve springs for mild cam $50
Casper's Harness NO EGR,NO AC,NO BS JUST THE BASICS HAS A FAN RELAY AND STOCK MASS AIR HOOKUP $700
Short block needs piston/rods reinstalled ran perfect with good oil psi, I would put new bearings ,to be honest I don't think all the original bearings are still here anyways. $200 Sale pending
Stock Mass Air sensor $50
Stock rad fan $40
Black headlight and tail bezels $85 Sold
Ecu stock $75
Stock rad fan $40
