S
		sweetgn
Guest
Just curious. I have run 12.96 before on 1 stage alcohol injection( 70% isopropyl) with about 16 lbs of boost. Lately after putting in two stage alcohol injection and a 'seventh injector' and running 24lbs of boost with no knock retard and O2's at 780, WHY am I running 13.6 at the approximate same temperature. I don't understand. Could the extra alcohol and fuel be just too much to put in the intake pipe? I have a .020" jet in the fuel and a combined jetting of .046" for the alcohol. I wouldn't think this would hurt with 24 lbs of boost. Could I be just on the border of bogging and not know it? I know some of it is the driver
, but I would think 24 lbs of boost would make a slight improvement since I was able to run high 12's before. By the way I have blue tops with the fuel pressure set at 46lbs with vacuum off.
Thanks for any help!!
