It's pegging the guage. I know the guage is close because I checked the resistances of the sending unit at certain pressures and it is right on with what Autometer told me it is supposed to be. I am running a HV front cover set up with the pump cover on the loose side. All oil passages thoroughly ported and radiused, bearings feed holes opened up to better match feed holes in block etc. Oil pressure is a tick under 25 hot.
I have to run a 40psi relief spring which keeps it at around 70 psi in upper rpms. The relief is not shimmed or blocked, and slides in and out perfectly freely.
Bearing clearances are all at about .0017 with the coating on them.
Pretty strange, I'm stumped.
