SignUp Now!Originally posted by JDSfastGN
part throttle knock is normal, since your pushing a lot of air through the motor but the chip is not in power enrichment so the fueling is a little off, pretty common with the TBs, if you go WOT and get no knock then i wouldn't worry about it
My bad for for giving false info, i thought it was above 4.00 on most chips where it would go into power enrichment mode and add the extra fueling. What is the TPS range on your chips Jim?
Originally posted by TurboJim
Hooffahh..been awhile since I looked, but I believe it was something like 160lv8 or 60% throttle..... I sometimes moved it from stock, sometimes I left it. Depends on the car, and I dont recall where yours is. If you have DS you can see it commanded. If it really matters, and if I still have your bin file, I can look.
Jim
