I blew a head gasket before Buick day.I used to have ARP Bolts,but now I am using ARP Studs!I am sticking with the same Gasket( Victor) I used last time it blew 2 years ago!When I pulled it down, I retorqued the heads and found a center bolt loose!The last time I blew it was #4 then #3, this time it was#3 with #4 going!I want to try and stop this from happening!Not showing alot of knock(very rarely .2- 5 counts when I get it)So I've heard you should torque them, back them off , then retorque them.Also torque them, run them through two heat cycles , then retorque them, but that souns like a lot of work having to take the exhaust manifolds off to retorque!Any Ideas would be greatly Appreciated!
Thanks,
Ed
Thanks,
Ed
