Torque Converter flush
Blown&Injected
I have NO problem grinding welds (I don't believe the converter will fit in my lathe), and welding; but man, do I really have to open the converter to clean it out?
When I've replaced a trans I also went with new converter, so I never thought about it. Some cat in trans talk said something about openning the converter to clean it out.
Can I let the converter drain for a few days, fill it with a solvent like lacquer thinner, let it soak for a few days drain and repeat?
Also seems like the converter could be welded in an unbalanced* position without a weld fixture.
*Unbalanced. The two shells not parallel, heat warp, mounting points not 90* to the converter snout...seems like trouble to me and I fabricate stuff for aerospace.
If you want to re-use the converter and you want it right send it to a reputable place ie; PTS and have it cleaned, checked, rebuilt and balanced also if interested have it restalled. Your asking for trouble if you don't and you maybe chasing ghost w/your new trannie.
If you can cut and clean a converter with just a lathe or griinder, You are the man!!
Not to be negative, but it will never work. It is a process only a converter co. can perform. DO NOT ATTEMPT!!!!
Send out to someone reputable and forget it.
like i said, sounds like trouble to me.
if it did fit in my lathe, it would be easy to make a clean accurate cut through the case.
Bruce, how much to go through it?
Routine procedure here.
Steve,
We, at TCI, can fix you up too. If you are still in need of assistance, give our guys a ring at 662-224-8972.
