Mnt86SS
Large Member
- Jul 10, 2008
Just recently my 87 GN has developed a ticking sound. At first it gave me a minor heart attack, as it sounded like valvetrain noise, but lower in the engine bay. After throwing it on the lift and running it, it's definitely coming from the converter / flexplate area.
I disconnected the converter and started the car, and no more ticking.
So before I rip the trans out, I'm wondering if this is a converter issue or a trans pump issue? I was having problems with the converter not wanting to unlock at low speeds, even after replacing the TCC valve. And as I spin the converter while it's disconnected, I can hear a faint clicking noise.
The current combo on the car is:
TA49 Turbo
50lb injectors
Turbo tweek chip set for 16lbs on 93
LT1 Maf and translator
Front mount intercooler
No cat
3 inch downpipe with external Turbonetics wastegate
Walbro 255 with hotwire kit
Basically the usual GN bolt on stuff. The torque converter is stock. Supposedly the trans was rebuilt before I got it, but assuming it wasn't, the car has 83k miles on it.
What do you guys think?
TA49 Turbo
50lb injectors
No cat
