trick86
Solid Member
- Nov 9, 2009
Just collecting everything for headgasket replacement on a Stage 1 -4.1 with aluminum M&A heads, here's my list of required stuff so far:
-fel-pro 1026's
-ARP head bolts
-RVT sealant
Couple of questions, should I skim sealant around coolant holes at headgasket? torque spec and sequence(pic)?
The car seems to be lossing coolant, some leaking out rear of head passenger side, plugs are too clean(all except one), slight misfire on cold overnight startup untill the sweet smell in exhaust is burned off, wonky O2 numbers especially with engine under decel or vaccum, no coolant in oil....yet.
If anyone has any tips please do pass them on, thanks. Byron
-fel-pro 1026's
-ARP head bolts
-RVT sealant
