Torque Spec for intake manifold bolts
Description Ft-Lbs N-M
Spark Plugs 20 28
Main Bearing caps to block 100 135
Balancer Bolt to Crank (min) 219 297
Connecting Rod Bolts 40 54
Sepentine Belt Pulley to Balancer 25 33
Flywheel To Crank 60 81
Oil Pan Drain Plug 30 41
Oil Pump Pressure Regulator Retainer 35 48
Oil Gallery Plugs 25 34
Oil Pressure Switch to Cylinder Block 24 32
Oil Filter Assembly to Pump Cover (center bolt) 18 24
Timing Chain Cover to Block 22 30
Water Pump Pulley 21 29
Thermostat Bolt to Intake 13 18
Intake Manifold to Head (in proper sequence), see below 32 44
Exhaust Header to Head 37 50
Engine Mount to Block 59 80
Timing Chain Sprocket 31 42
Rocker Arm Shaft to Head 25 35
Accessory Bracket to Head 37 50
Alternator Mounting Bracket Through Alternator to Head at Pivot Location 44 60
Starter To Block 35 48
Cam Sensor Hold-Down Clamp 20 27
Transmission to Block 35 48
Bolt-Special Movable Timing Chain Dampener 14 19
Knock Sensor to Block 14 19
Fuel pump block off to Timing Cover 22 30
Turbocharger Inlet Adapter to Turbocharger 17 23
Turbocharger oil drain pipe to Turbocharger Center Housing 22 30
Turbocharger Compressor Housing to Center Housing 13 17
Turbocharger Turbine Housing to Center Housing 15 20
Exhaust Manifold to Turbine Housing 20 27
Power Steering Pump to Accessory Bracket 20 27
Turbocharger Mounting Bracket to Head 37 50
Turbocharger and Elbow Heat Shields to Mounting Bracket 20 27
Turbocharger to Mounting bracket 20 27
Throttle Body to Intake Manifold 20 27
Front Vacuum Line Bracket to Intake Manifold 20 27
Engine mount to frame mount 48 65
Engine frame mount to frame 33 45
Air Conditioning Compressor to accessory bracket 37 50
Power Steering Pump to accessory bracket 20 27
Shifter cable bracket to transmission 20 27
Flywheel to torque converter 46 63
Transmission mount to transmission 25 34
Transmission mount to frame 40 55
U-joint strap at rear axle 16 22
Torque Values (in INCH LBS)
Description *INCH lbs.* N-M
Oil Pan to Block 88 10
Oil Screen Pick-up to Block 96 11
Oil Pump Cover to Timing Chain Cover 141 16
Water Pump to Timing Chain Cover 115 13
Valve Cover to Head 44 5
Flywheel Cover 48 6
Vacuum Harness to Throttle Body 35 4
Throttle valve cable to transmission 80 9
Torque converter cover to transmission 53 6
