Torque spec. on convrtor to flywheel bolts?
NCC1701
What are they and will a normal 1/2 drive torque wrench work or do I need to get one of those adapters that are like a boxed in wrench on one side and snap onto the torque wrench on the other. Not sure what they are called exactly, but hopefully someone knows what I am refering to:) Also, where can i get new torque convertor to fly wheel bolts? Is it something I can get from the local hardware store, or do I need to order some from one of the vendors???
Thanks In Adavance:D
Trying to cover all my bases before the new Convertor arrives:)
You should be able to reuse the original bolts on your new converter. They usually torque somewhere around 25 ft lbs. Most 1/2 inch torque wrenches won't go that low, just use some red loctite on the threads and get them good and tight with your 15 mm wrench.
trbo668bird............
Thanks for the response, I appreciate any and all info provided:)
