Can't find numbers only see precision
danomano80
Can anybody id this for me and point me in direction to reseal hot side, it's leaking out of both sides from previous owner putting together. One bolt is cross threaded and not tight, pretty sure I can fix threads for that. Been looking and looking and can't match this turbo up to any I know or have seen with cold big hot smaller. Thanks in advance
You would have to measure the wheels to get the turbo size, its common for the covers to be bigger on the cold side, visually from the outside turbos look similar but that looks big i would guess older pte 6765 4" cover precision .63 housing
Reed at Work Turbo fixes older units like that
What would you suggest for bolt in replacement turbo for good street ability?
This info previous owner gave me on trans and converter.
The Trans is a Stage 2 Extreme Automatics built by Lonnie Deers and the converter is a PTC that cost about 3k with all its upgrades
9.5 ptc or 10" ptc? big difference , whats the other info on the motor, heads?
Previous owner said, ptc converter is for a 62/62 turbo not the 72 that is on it, 210 cam, billet center mains, forged pistons, c6 maf, big titanium valves in head, heads and intake port matched, it has maf translator and scanmaster. I've done valve cover and intake gaskets to get rid of oil leaks, have verified no vacuum leaks with smoke machine. I replaced iac and readjusted tps cause it would not start without throttle, finally got it to idle better when I noticed the leaks on the turbo. I have picture of chip, couldn't really find any good info on it though
Appears to be an early Extender chip for the Translator +. PM TurboBob aka Bob Bailey the info., he should know exactly what it was designed as since he did the chips and designed the Translator and is always helpful.
From my limited experience with the older stuff.
B early translator?
S stock data stream
0 should be injector size not on my list
5 98 octane alky. chip for the T+
7 100% wastegate d.c. typical for alky. and race chips
A stock cam
0 no anti-theft
F current software revision
A no clue
72mm turbo is way to big , i would look into a modern 62 to 64 mm , it will support way more power then you will need and spool 10x as fast as the 72
Hello danomano80 and everyone else.
Here's how you can ID any Precision Buick turbo that's been built since 2001.
Your compressor cover is secured to the backing plate with 2 bolt clamps and 13mm bolts.
Remove the clamps and you'll find either a CNC machined code, or hand engraved code that says CC_ -__ .
There's 4 codes. CCE for the E cover, CCS and CCSC for the SP and S Cast Ported covers and CCH for the HP cover.
I can tell you by looking at your pictures, you have a journal bearing turbo. But we need to find the compressor cover code to be able to ID what it is. If it's a 72mm, that tells me it's probably an old school PT7268 or PT72HPQ. Because all of the 72mm turbos made since the late 2000's have been ball bearing.
Now that we have that figured out, let's move to the hot side and figure out what turbine wheel your turbo has, so we can be 100% positive on what you've got.
Unbolt the 4 bolts on the downpipe and pull it away from the turbine housing. On the flat side of the turbine housing, just above the smaller wastegate discharge hole, you will see another CNC cut part number. On the Buick turbine housings, you will see three letters, followed by one number, then a dash, then two numbers. The code looks like this. THB_-__. If your turbo is a PT7268 or PT72HPQ it should be a .85 A/R and the code will say THB5-68. The 5 means .85 A/R. The 68 means it has the 68mm turbine wheel.
Here are some pictures that show you what these codes look like.
This is my new Next Gen PT6466.
In this picture, you'll see the 2 bolt backing plate clamp that's bolted down with two 13mm bolts. Remove the clamp until you find the CNC cut or hand engraved part number. On my turbo it was behind the lower clamp closest to the comp cover discharge.
Loosen both bolts and remove one so you can swing the backing plate clamp away and uncover the part number. You might get lucky on your first try, but your results may vary.
As you can see, mine is hand engraved and reads CCSC64-23. This means Compressor Cover S Cast, 64mm compressor wheel and the Next Gen series 23. When you reinstall the backing plate clamp, tighten the bolts in a criss cross fashion, hand tight. On the HP compressor cover turbos, there's no o-ring that seals the compressor cover to backing plate. And on the E and S covers, there is an o-ring that seals the compressor cover to the backing plate.
Now for ID'ing what turbine wheel your turbo has.
Just above the wastegate hole, you can see the THB5-66 part number code. THB means Turbine Housing Buick. 5 means .85 A/R and 66 means 66mm turbine wheel.
In your pictures, I didn't see the current turbo ID plate that get's installed on all PTE turbos today. That being the case, there is one more location you can look to help verify what turbo you have. Before the silver and red turbo ID plates came into being, they used to hand engrave the turbo part number, on the compressor cover's discharge. This engraving would typically be covered up by the intercooler hose. The engraving could have said PTB___-____, or it could say something like PT6262. It just depends on the time frame it was built. Today's turbo ID plate has the SN serial number and the 11 digit turbo PN or part number on it.
Here's an example of our current turbo ID plate.
That's a 20904207568 GEN2 PT6062 BB SP CC W/ BUICK 3-BOLT INLET .63 A/R HD ACTUATOR
A fantastic street turbo that's good for 750 flywheel hp.
About now, you might be asking me, "Hey? What's up with those double nuts on your 3-bolt studs?"
That's my friends, is a Jedi Master pro-tip I was taught many years ago, from one of our real Turbo Buick Legends, Mr. Lawrence Conley.
And I'll gladly share it with everyone. It's not the only way to fix a problem, but it has absolutely worked perfectly for me.
Purchase double ended M10-1.50 x 42mm longer studs. Amazon.
Purchase standard thickness M10-1.50 SS nuts. Amazon.
Purchase M10-1.50 half lock SS jam nuts. Amazon.
You see, what happens is, customer buys a new turbo and new standard thickness nuts along with the 3-bolt gasket of their choice. Cranks the nuts down and goes racing. Well, as the new turbo goes through a few heat cycles and 16 psi to MOON BOOST passes, heat and vibration cause the nuts to come loose. And sooner, rather than later, one or two fall off the car and you get a massive exhaust leak. Not fun.
This is where the Jedi Master trick with the longer studs and double nuts comes in clutch.
On every turbo I've installed on my own cars over the past 30 years of hot rodding Turbo Buicks, I have done this exact proceedure.
SCE copper 3-bolt gasket, P/N 4172. Summit Racing.
Permatex Ultra-Copper rtv. Vatozone 🤣
I coat both sides of the copper gasket thoroughly. But not so much that it's a massive blob, but enough for a good seal. Install turbo and tighten the standard thickness nuts down nice and tight, to the point the gasket's sealing ring gets a nice crush and the rtv slightly oozes out. Then I install the jam nuts nice and tight. Now for the most important step. I let the RTV cure for 48 hours before starting the car. This gives it plenty of time to cure. As well as making it easy to go back and clean up the 3-bolt joint from any blobbed out rtv. Then, after I've driven the car 3 times, I park it and let it cool down completely, to the point of having a safe to touch turbo with no heat. I then go back and check the jam nuts for tightness. Everyone I have ever done like this, has been rock solid and I've never had one come loose.
Welp, they're giving me the wrap it up signal, so I'll leave y'all with that.
Have a great weekend everybody. And let us know what you find on your turbo danomano80.
- Patrick
Precision Turbo & Engine
Technical Sales Representative
- Patrick
Thanks a million, I'll pull it apart as soon as I can and get back to you with all the numbers. Thank you again for the wealth of knowledge
No problemo sir, glad to help.
I had my turbo sitting here in front of me and thought, hey, why not. It’s just sitting here waiting on me. 🤣
Feel free to message me on here, or at my work email.
patrick.rubio@Wabtec.com
- Patrick
