95 Ft Lbs with ARP moly lube, 130 Ft Lbs with motor oil is the old ARP instructions. I just got a new set of ARP main studs and it says 110 Ft Lbs using the Ultra Torque lube they came with. It says to use the torque spec and lubricant that was used when the block was line honed. Why they changed the lube, I don't know.
