JustABuick
- Feb 13, 2013
Hey all,
I searched the forum already, but didn't find anything, so I'll start a thread. I am installing a powerlogger, and am using a TPS harness from Julio so I can run the green MAP wire to the powerlogger's analog board. I have it installed so the stock male TPS plug is in the TPS harness female plug provided.
My question is: the Casper's volt booster is essentially setup the same way- it has an alternate TPS male plug and a female TPS plug. Is it possible to run both the TPS harness and Volt booster? I am thinking I can run the male volt booster plug into the stock female location near the throttle body, and the TPS male plug into female plug on the volt booster harness.
